1 - 8 of 8 Posts
Hi Everyone, I Just purchased my first CX500 and I am trying to switch out the tail light. I bought a universal 3 function(stop, turn, tail) taillight from advanced auto parts because I really liked the look of it. I mounted it in the original taillight mounting bracket that came with the bike. My problem is I have a black and red wire coming out of the new light, and a brown, green, and green and yellow wire coming from the bike to the Tail light. Is it possible to make this light work with the bike?
Here are some pictures.
Uploaded with ImageShack.us
If your new lamp only has two wires then it can't be a Stop AND Tail let alone and indicator light as well
If you think about it you need 3 wires for a stop/tail lamp.
1 wire for the Brake lamp
1 Wire for the Tail lamp
1 wire for the ground to the frame.
If it could do indicators as well it would need another 2 wires as well one for each side
I also thought it was a "this can function as one of these 3" so I went back to the store the guy there assured me it is not. I guess if I ground the third wire to the light it should work. I'll let you know how I make out tomorrow. Thanks for the help guys
What about your license plate lamp?
trailer light. two wires in ground on the frame.
How do you feel about the double taillight look? (sounds like it might be the only turn signal option)
Marshallf3: Good question; I would guess that there isn't a clear lens portion on the bottom of the lamp.
Good luck, JoeyRock, and I like the tail lamp style. Hope it works out for you.
coop
I don't see one on his but usually there is a clear section at the bottom letting the running light shine down on the plate.
1 - 8 of 8 Posts
