Hi!
I have 84 CX650 Eurosport and now having difficulty to find Rear Carrier.
Although it was popular in Europe, I still can't find something reasonable.
What is the best solution for this?
I just wanted to mount a GIVI top case.
Thank you.
you could fabricate one yourself from some pencil rod (also known as round stock) steel just an idea:) I also saw a member here that was making and selling them here hope this was helpful
If you make one, you can either put a pipe around tge rrar grab rail or replace the rear grab rail with a solid tube with tapped threads on both ends.
Then fasten a rack made from agle sides and flat middle supports.
Finding or making a place to support the rear of the rack might be the challang
An extension from the rear turn signal mounting bolts might work.
