Not doubting your find...but what extra information do you have that suggests this is suitable/equivalent?:)
Which model do you have? Most of these bikes have a spring that sits around the opposite end of the brake shaft and pushes against the arm to return the brake to its resting position when the pedal is released.
FWIW, when the spring that presses against the arm on mine broke and I didn't have a spare I welded a tab onto the lever and made another tab to mount under the engine mount bolt and used a spring salvaged from a washing machine decades before (I knew it would be handy eventually) for a similar setup.
