I replaced my rear brake shoes today and have everything put back together but not torqued. I'm experiencing what was described in this post from a decade ago, where after torquing down the axle nut the brake cover is locked down to the hub so it can't float independently. In other words, if the brake torque arm is attached then the wheel won't spin freely in neutral. I also notice that the left end of the axle sat a couple of millimeters proud of the swing arm clamp in the photos I took before disassembly, but now the end is almost flush.
The factory manual says on page 14-8 to torque the axle nut before tightening the axle fixing bolt, but that gets me to the current condition. It seems based on the advice from the post I linked above that I should snug up the axle nut to remove free play, but then torque the axle fixing bolt before final torque is applied to the axle nut.
Does that sound right, or am I missing something serious?
UPDATE (since I hate it when searching for answers in posts like this and they seem unresolved): Turns out I was making a big deal of of nothing, or better put, misunderstanding what I was seeing when putting the rear end back together. Thanks to everyone who responded. I did follow the Swedish method but really what I needed was a fresh day and fresh pair of eyes. Everything works fine even if the brake cover plate doesn't spin freely once the axle is fully torqued. Of course it helps to connect the torque arm to the brake before torquing down fully.
