Should I be able to crank it by hand with the engine off? Because I can't.
Hollywould · Registered Joined Jun 5, 2011 · 37 Posts Discussion Starter · #1 · Jul 1, 2011 Only show this user Should I be able to crank it by hand with the engine off? Because I can't.
Allan · Registered Joined Aug 3, 2010 · 3,999 Posts #2 · Jul 1, 2011 Only show this user If you have a 500,,the fan is not electric,,it is attached to the cam shaft and will not turn by hand.
Cobram · Registered Joined Aug 3, 2010 · 3,530 Posts #3 · Jul 1, 2011 Only show this user No, there is no fan clutch, it's attached to the camshaft. If you can turn it, you have a big problem.
Hollywould · Registered Joined Jun 5, 2011 · 37 Posts Discussion Starter · #4 · Jul 1, 2011 Only show this user Phew! I was afraid it was the other way around. Thanks! Better to feel a bit silly than have a big problem and not know it.
