Hello--
I just got to installing my HALL TAI Ignition Module on my GL650. When doing the initial timing procedure, I noticed the marks in the instructions are only for the 500 and not 650. However, after comparing the two flywheels, I set about timing the motor. (also the instructions are missing how to tie the relay into the system...)
From what I can understand, the LED is supposed to be on from the double line to the FR mark. However, on my 650, the LED is on from just above the FR mark to the TDC mark. I modified the info graphic to reflect my timing vs what its supposed to be. Red is manual, blue is what im seeing.
Someone on the fb page suggested I had the wrong rotor as that's what happened with him. Is that why my timing is way off?
For a $200 kit, I kinda expected it to be a little better. I know these are hand built and whatnot, but possibly getting the wrong rotor, incorrect instructions, missing wiring diagrams, having to pry the case off the module due to too much superglue on the 3d printed wiring guide, and getting the wrong bolts really does put a sour taste in my mouth
If i have to wait for a replacement rotor, thats going to be 2+ weeks for shipping.
Heres a video of the issue:
