Guys - had a need to make a bike wiring simplifier / controller for a harley custom chopper that frequents my shed - the vibration on this thing just shakes most things apart-
Had a look at the motogadget m-unit - fell off my chair at the price and unnecessary blue tooth functionality, had a look att he NWT units - and the axel joost - but nothing quite fit the price point and the desire not to use custom controls -
I wanted a general unit that would accept programmable input polarities from standard controls, and provide the control outputs with a few whistles -
breake flashing, indicator programmable time out , headlight low bean modulator, the abiltyi to use the harley button psuh left and right indicator controls - so the ability to latch inputs. Dont need any bluetooth crapbut did decide to add a built in heated grip control - using the existing controls.
Had a look at the resettable fuse option - but it adds more complexity than its worth - so instead - used 30A mostets with two main circuits of master fuse ( eg 2x10A) or you can fuse the indicidual outputs if desired.
so doing a batch of 10 units - target price isthe $US 150 mark - its not as small or pretty as a motogadget - but it hits the spot for practicailty -
initial model - havent got the boards back yet. blue is the screw terminal blocks
Oh unit has a power input so no main relay switching needed - draws zero at standby until power applied to the On terminal.
Serial terminal setup shown --set once and forget - but shows the options.
As it uses and arduino Nano as the core - planning to just make the code available for those who want to add features of there own.
Do we have any interest ?
Rayman
Rayman
