Quick fork oil change
1 reading
6.6K views 10 replies 6 participants last post by  Swensy7
#1 ·
Hi.
I was wondering if it is possible to 'quickly' change the front fork oil on my cx500 1982.
Can I just loosen number 22 on this picture and put the new oil in it and then put the nut back on ? (after draining the old oil via the drain plug of course).
Or do I really have to take off the entire fork ?
Many thanks for the reply.
Regards,
Wes
#6 ·
Thank you. It is clear now.
Also, I have a CX500C 1982. The owners manual says 135-140ml oil per side. But this manual is for 78/80 bikes.
Is it the same for the 82 model or does it require a different level ?
Many thanks.
#8 ·
"(after draining the old oil via the drain plug of course)"
Would someone kindly point out the drain plug for me?
Is it #14?
