Seriously, i hope this would be a simple question, it's ONE wire... so maybe someone can help an electrical diagram illiterate guy out(I've never been good with wiring, so bear with me).
After modifying my fairing, and having separated and marked very clearly any wires that came apart when i took it off, i replaced evertyhing I marked, and everything worked great. Except the tail light. Whatever wire controls that came out after i removed the fairing, and therefor wasn't marked. Everything else works fine, brake lights, signals, etc. Just the taillights don't come on.
Out of all the wires that are in that 1978 rat's nest behind the light, a green wire is the only one i suspect(clean, shiney bullet connector with no corrosion at all). My question is if that's the wire i'm missing, and where it might go. I'm really bad with wiring diagrams, and as such, even after looking them over, i'm pretty sure this is my wire, but i'm unsure of where to plug it in. If pictures are required, let me know and i'll get out there as soon as i can and get a couple of shots. Thanks again, i really appreciate it in advance.
