I noticed oil spot and saw the front of my motor is leaking oil from somewhere. Looking for the leak I noticed the tachometer cable was not hooked up at all (the tach has never worked) and was halfway in the hole it belongs sitting loosely. I can barely see up in there. I'm assuming that if the cable is not mounted properly it will leak oil correct. I pulled softly and it just pulled right out. I unloosened a phillips screw, shoved the tach cable end back in the hole it belongs on the engine, tightened the screw back and nothing would hold the tach cable in. Question is: Firstly, is there suppused to be an o ring on the cable end, mine doesn't have any o ring. Secondly, how does the tach cable attach correctly to the engine? I don't care as much about my tach working or not I just want to properly mount the cable so there will be no leakage (if that is causing the oil spots). Thirdly, while I'm asking, Is it a big job (on a cx650c)to move the radiator out of the way in case I need to mess with the front of the block to find the leak if that is not it? Thanks guys, -carter
