Has anyone done or know of a propane conversion to one of ours or a different species of bike? Besides an ugly tank was wondering how or if this would work and has been done.
Fuel from water is the holy grail and it fascinates me. I'd love to ride on fuel
from the tap but wont be parting with any cash until I'm fully convinced
The problem here is physics, it takes more energy to break the H2O bond then you'll get out of it in return as a fuel.
LPG is nice but the carb system is very tricky.
CNG/LNG is ideal but is even more difficult to deal with. We actually have some CNG stations now and a lot of vehicles in town that run off of it, it's selling for a bit over $1 a gallon. As with LPG, it really requires a much higher compression engine to get the full benefit from
http://en.wikipedia.org/wiki/Gasoline_gallon_equivalent
When I first laid eyes on my CX650E it looked like it had been ridden hard and put away wet. No seat just the pan, no plastic body panels, dented rusty tank with no cap...
I stood staring at it with a frown on my face while the owner fiddled with a car battery and 1 LB. propane cylinder.
He hooked the battery up with one jumper cable, grounding the other terminal to the frame and hooked the propane tank to a valve and rubber hose, the end of which he poked into the air intake for the air cleaner.
On went the(propane) gas valve, cranking took about 10 seconds and it purred to life.
I was reaching for my wallet before I knew what I was doing
It WILL run for sure,just not sure how well.
Stan
I'm not sure if it's true, but I've been told that many motorbikes in Thailand run on LPG.
Here in OZ, LPG for cars and trucks is becoming very popular, and you know what happens then.....
When I first started using it, the LPG cost 8c a litre, now I'm paying 64c a litre.
I've overcome the problem of running out of LPG in my truck by carrying a BBQ gas bottle with me. All you have to do is turn it upside down and fix it higher than the carby, run a hose in the top of the carby, then turn the gas on.
I think it might be Iceland or maybe Norway, but one country has made a 'hydrogen highway' and installed hydrogen fueling stations all along a stretch of coastline. There are experimental hydrogen stations that can use solar power to split water into hydrogen fuel, that would be an ideal solution if it can be made to work. Hate to say it but our gasoline powered vehicle days are numbered.
