I've looked around and tried a bunch of trouble shooting already but I still haven't got the issue sorted out.
78' CX500, stock airbox, aftermarket exhaust w/ muffler
Symptoms: Right cylinder doesn't fire at idle. Inconsistent at 2k and above (misfires and popping on decel)
Things I've done:
Help me out guys I'm going crazy over this!
Things I've done:
- Brass rod mod
- Swapped and replaced plugs
- Rebuilt the Carbs like 4 times (stock jets and slightly larger jets, neither fix it, 78/112 80/120 I think?)
- Adjusted mixture screw a full turn in each direction (out 2.5 currently)
- Checked for spark on both cyl
- Valve adjustment? Idk if this would effect anything but I'm putting it in there
- Compression check, both cyl are nearly identical
- Checked briefly for vacuum leaks
