1 - 8 of 8 Posts
I have several chrome pieces that I want to paint since the chrome is in bad shape. I dont really want to spend the money on media blasting and poweder coating or rechroming. So my thought is to repaint with a durable Black spraycan paint of like the hammered finish stuff.
I just want to know what the best way to prep the parts for best adhesion of the paint.
Thanks
I painted the chrome front fender on my (see my avatar) 78 CX500 using the Hammered Copper paint. What I did was to use a green kitchen scrubby pad to get the chrome all scratched up good, and some sandpaper on the rust on the back side.
The paint seemed to adhere well. I do have to say I thought the hammered finish would be cool, but was disappointed afterward with the look.
If you sand/grind back the chrome, hit the metal with some Red Oxide primer, then top coat. The oxide bites into the metal and also allows the paint to "grab" on to it.
If you can get hold of a spray can of "etch primer" it has some sort of acid in it that burns into the metal.
Its excellent for chrome and plated items.
· Administrator
2021 Benelli Leoncino Trail - 2021 CSC SG400 - 2017 SSR Buccaneer 250i - Several CX project bikes
If you're going to paint, get a catalyzed etching primer and high-fill catalyzed primer. Quality primer makes a WORLD of difference.
Never grind off chrome. Sand it (dry) by hand with 200 to 300 grit, then etching primer, then sandable primer, then sand with progressively finer grain until about 600. Then shoot a solid-color single-part catalyzed paint. Leave it as-is or color sand and rub out with a buffer. Clearcoat only necessary if you're doing candies, pearls, or metal flecks.
You can get all this stuff at a real automotive paint store, and an inexpensive siphon paint gun at Harbor Freight.
Charles.
Charles.
I've always wet sanded my chrome followed with a THOROUGH drying out - why do you suggest dry? (curious)
I sanded my front fender to rough it up and then put on some 'self etch' primer, and then some gloss black over top, and it's been good for 3 years now.
1 - 8 of 8 Posts
