1 - 15 of 15 Posts
I’am getting some air puffing out of the left cylinder through the carb there is no oil in the coolant or coolant in the oil am I missing something here ?
Possible valve problem? Leakdown or compression test?
Was this sudden onset or developed over time?
How does the bike run?
Discussion Starter #4
Bike is stock gl 650 it happened after a short ride I shut the bike off and had a short conversation with a freind I went to start the bike and got a pretty good back fire and puff of smoke from under the fuel tank around carb area , thanks for the reply .
Was the backfire and puff of smoke a one time event or are you now getting regular puffing of air out of the left carb?
Discussion Starter #9
One time event bike runs puffing air out where carb mounts to the head
Discussion Starter #10
I’ll take a video and see if I can upload it after I get off work thanks guys
Have you checked the condition of the sealing O-ring?
Discussion Starter #15
Ok guys this is what happened: when the bike back fired it blew the rubber boot off the carburetor that’s what was causing the air to puff out of the boot ! That simple thanks for all the suggestions they helped . Took a quick ride on the freeway got full acceleration bike performed well thank you all .
1 - 15 of 15 Posts
