I would never discourage people from fitting pod filters but just like people to know what they are actually doing and the changes it will make to the engine/system.
As the rev range of carburation of these Constant velocity carbs is controlled basically in 3 parts the lower rev band section of the slow speed idle circuit cannot be changed thus by fitting Pod filters with greater air-flow and even after re-jetting that part of the rev band of the engine may well be a leaner mixture which is not good for the engine over a period of time and the idle mixture screw may not be able to be adjusted correctly to compensate.
This means that a stock machine may well accelerate from stop faster.This of course may not be a concern as most people who,"Cafe Racer" style may not use the machines for commuting or long trips whereby they are not stopping and starting lot and may gain power,at the expense of fuel consumption,at higher rev bands which is what they want.
A colourtune unit is useful for checking the mixture at these lower idle speeds.
http://www.carbtune.co.uk/colortune.html
and if you ever did decide to buy one you need the 12mm adaptor for our bikes,
http://cgi.ebay.co.uk/GUNSON-COLORT...t=UK_Hand_Tools_Equipment&hash=item25613d8475
You can get the superb full tuning kit from John Morgan,
http://www.carbtune.co.uk/carbcust5.html
http://www.carbtune.co.uk/index.html
I have and use both
