1 - 8 of 8 Posts
One comes across the most interesting motorcycles at the bi-annual Slimey Crud Run at Pine Bluff, Wisconsin, USA. Photo snapped on May 03, 2015.
Wait, where are they, I just spent 5 minutes looking. I hope it's not obvious or I'm going to feel like an idiot.
Ah, found them across from the reg.
Nice bike, nice pic. I like how the crash bar, seat support, and monoshock coil lines fit together in a weird and wonderful way.
Looking back at it again, I can see that the master cylinder brake reservoir is not mounted in the standard position... and there doesn't seem to be a provision for anything bar the throttle cables/grip on the right side of the bars.
Assuming that the lever on the left bar remains a clutch lever (you can see the end of a cable in the end of the grip), where's the front brake actuator?
Looks like a res near the headlight and as the control levers are
end mounted the lever is probably hiding.
The master could be hidden on the other side of headlight
or under it most likely
1 - 8 of 8 Posts
