So I'm back. I'd been having troubles since my reserve has been clogged. I got fed up, drained the tank, and pulled it off. I poked around, but didn't see anything wrong so I reassembled it (should I have sprayed it with something?) and put it back on.
Well, now I have two problems: the reserve is still clogged, but now the petcock leaks gas (rapidly when petcock is ON and the engine is off, slowly while petcock is OFF). It's not feeding gas very well (either too much or too little), so the engine has been hard to start, a bit stutttery, prone to stall at idle, and needing a pretty heavy throttle.
It's a vacuum fed petcock, and I half suspect that that is the source of my problems. I'm about to go check the membrane for punctures of any kind.
So:
1. What did I reassemble wrong? And
2. How do I unblock the reserve feed?
So:
