IIRC, the CX500 models that came with non-vacuum petcocks have 16mm threads but the GL500, CX/GL650 and later CX500 models that came with vacuum petcocks have 18mm threads. Hopefully someone who knows for sure will either confirm or correct that.
If you convert to a non-vacuum petcock you will also need to cap the barb on the left side of the right carb where the vacuum hose connects.
FWIW, I have a bunch of old petcock parts and could send you what you need but with postage rates being what they are a new one from China would probably cost you less than postage from Canada, not to mention that there is no guarantee that the one you have will work - there is a rubber "donut (actually a disc with 4 holes) in the main valve of the petcock that can deteriorate with age & use plus the vacuum part would probably need to be rebuilt (you can get a kit for that but the donut is not available.
Welcome to the forum. Please add your location to your profile and your bike's model and model year to your signature so that you don't have to remember to tell us every time and we don't have to keep asking when you forget (see Forum Settings link in my signature).
