1 - 17 of 17 Posts
Hi all,
After loads of time trying to re-fit the stat assembally....now noticed the elbows have a hairline splits in them so could someone please give me the part numbers so I can replace them.
Thanks in advance.
MrB
Hi all,
Thanks in advance.
MrB
part 6 here
22 bucks
19421415000
Well ...just checked out the part number with David Silvers...and the elbow is now discontinude......so now looks like the ole liquid metal repair is the next best thing....i hope it works
good luck,if it doesnt,i have a spare,ill send it back to the uk
Bullshit! ..... There has got to be some machinist somewhere ... outta work n hungry ..... New to the bike game n have seen this thread play out to many times .... Figure a guy could make a fortune hitting up forums like this n making tiny parts for reasonable $ ........ Maybe I'll start school n do it myself .... Ha
Tony,are you sure?
id guess this is a cast part,not a machined part.
like i said.cmsl have 3 left.a long way from essex.but if he can fix it, fine,its only a low pressure water pipe
Sorry.... forgot to thank you all for the quick responces....did think about the liquid metal route but decided to buy some new from CMSNL...just noticed they are in Holland...hope i dont get any porn attached, the Mrs would not be happy lol
Sorry.... forgot to thank you all for the quick responces....did think about the liquid meteal route but decided to buy some new from CMSNL...just noticed they are in Holland...hope i dont get any porn attached, the Mrs would not be happy lol
cmsl are a good company,you keep the bracket,send the porn to me,job sorted.
I understand...... Was just venting ...... Sry I yelled ... Haha .... Seems like one of us should geta lathe n a mill tho .... Hmmmmmm .... Maybe I'll start hunting on Craigslist .....
no worries,didnt know you yelled,CL,IS A LOT EASIER THAN FORMING PART 6.....HAha ha...thats shouting.lol,so the wise guys tell me
have a good week
CX500 Z 1978 , Rickman Polaris fairing, currently GL500 front, Ignitech etc. subject to change
To avoid a repeat :
I've also had these cracked elbows and seen others, the cause is using non-Honda o-rings of a standard metric size (nr.21 in the picture above). These will fit nicely in the grove but are just a bit fatter. Now tighten those two little bolts holding the elbow to the cylinder head, the elbow will not be flat on the machined surface because of the oversize o-ring and crack.
You won't really notice this untill you fill the cooling system or even later when things get warm and the pressure builds.
The lesson learned : if you don't have the correct Honda-sized o-rings, just use the old ones and a smear of sealant. Do not use other o-rings even if they seem to fit nicely.
I rememebr when i did mine I couldnt find new ones to fit, so i reused the old ones. I am actually surprised they DONT leak. Was all set to stuff them with sealant but go figure
To avoid a repeat :
Good point.I have an O-ring kit and there's nothing in it that I would use for this job.Some of the Rings can be used for the transfer pipes.I've re-used old rings and clear silicone bath sealer before
1 - 17 of 17 Posts
