1 - 8 of 8 Posts
Need the Honda part # for the o-ring seals on the elbow to the head (coolant)that comes from the thermostat housing. I have tried several that i thought would fit but they are still weeping coolant....even tried some silcon but to no avail.
Cheers in advance
MrB
Cheers in advance
MrB
i think all those coolant o rings are the same
number 17 f.e.
91302371023
(91301-MB6-003) O RING 21.9X2.5
Note: this part is superseded by 91301MB6003
number 20
9460850000
O RING 23X2.8
number 19
91307611000
(91307-PH7-660) O-RING (12.5X1.4)
Note: this part is superseded by 91307PH7660
number 18
91302657000
O-RING 53.8X3.1
Water elbow to head - 23 x 2.8mm [proprietry 23 x 3.
water elbow to tube - 21.9 x 2.3 [p 21.8 x 2.4.
Don't know about part numbers but these are the sizes. Fist size is from Honda, second size is what you can pick up at a bearing shop or similar.
I never buy this sort of stuff from Honda, it's too expensive. For the price of a couple OEM ones you can buy a handfull and have spares.
THANKYOU EVERYBODY
Don't worry about the metric sizes they are taken from the original imperial sizes.I took a pair of elbows into my local Plumbers supply and they just dug out some to suit
You can also get them from Plumbers suppliers,
Here's an O-ring size list,
http://globalcxglvtw...ilit=oring#p554
These have been added and thanks to by Terry Fouts
Westerville, Ohio
* 2 - fuel (idle) mixture screw (2.8 x 1.1 mm)
* 2 - float bowl drain screw (4.2 x 1.3 mm)
* 2 - CV Slide Top Limit Plug (6.9 x 1.3 mm)
* 1 - Accelerator pump passage at float bowl (5.0 x 1.3 mm)*
* 2 - Main Fuel Transfer Tubes (5.8 x 2.0 mm)
* 2 - Accelerator Fuel Transfer Tubes (3.8 x 2.0 mm)*
* 2 - Intake Manifold (40 x 2.6 mm)
Thanks.
Terry Fouts
Westerville, Ohio
1 - 8 of 8 Posts
