Thanks fellers.
I ripped the motor for this down today - for a few reasons.
1 - About 3 days after building this engine I had to take Mrs. Phreak to a fairly important doctors appointment on a stinking hot day. Aside from being new and tight i think the thermostat jammed closed and the motor overheated. Though this motor has now done 5,125 km in my standard with no apparent problems I feel better now that I have seen the bearings etc.
2 -I wanted to see the David Silvers camchain guide as there has been questions over the Silvers parts.
3 - This motor had a few minor noises from the top end even though camshaft and upper rockers and pins are new. Suspicion falls on the piston pins and exhaust valve guides, both of which will be replaced now and the heads then have their seats recut. The valves were only ground last time. Before dismantling the heads I'll put them on my head tester to make sure they've been holding pressure. These noises weren't actually there when the motor was first assembled. Overheat?
Everything was found to be good so after cleaning everything I'll just reassemble with the same parts - except for the piston pins and head rebuilds.
Camchain has plenty of adjustment left.
Outside of chain marked so it goes back in the same orientation.
The tensioner and guide. The guide is Silvers, the tensioner Honda. Both are still good.
Gearbox removed. This will just be put back as is.
I added pieces to my crank puller today so it could be used here. just needs a final cleanup and paint now. It works well.
