I'm trying really hard to get a beautiful paint job done with spray cans. Learned today that I need more than 2 coats of base coat and 2 coats of clear. I have done some practice and looked online at a lot of information on wiki how and youtube. I'm using Valspar primer, base and clear.
I roughed up with 600 then used paint thinner and made sure the surface was clean. Then primed several coats and let dry. Then sanded with 600, cleaned, and did a few coats of base coat. Black primer with black paint. Now I wish I had used red primer but ooh well. Anyway, I didn't let the base coat dry, I sprayed clear right over a semi wet case coat. Hoping the clear would "melt" right in to the base coat. I've heard that letting the base coat fully dry the clear coat may eventually peel off. maybe I should have let the base dry, then sand with 1500 to give the clear something to bite to.
Anyway, so when I looked at my clearcoat in the light, it was not smooth. I sanded with 1500 then used maybe a to fine of a polishing compound with a buffer. But I couldnt seem to get rid of all of the orange peel, or unevenness. I'm thinking I might have to sand it all down flat and smooth to get rid of any uneven ness and then paint several coats so that I don't cut through to the primer when sanding the base coat to make it perfectly even before spraying clear. Then many coats of clear, so that can be sanded and buffed, without cutting into the base coat.
Any suggestions from experianced people who just dont go for "good enough" please. I want to do a good job so that I can do the same for others.
