Has anyone widened the two oblong mount holes of the pump so that you could get more use out of a stretched chain?
Last fall I noticed a rattle sound at higher rpm and recently decided to pull the front cover and adjust the chain and change a leaky cam oil seal.
I found that my oil pump chain is so loose that it has been hitting the clutch basket. The pivot adjust wont pick up much slack at all.
I have ordered a new chain but am curious if others have opened up the mount holes some to work with a less stretched chain.
