Appears I'm having a consistent oil leak. From what I'm seeing this is pretty common and looks like I just need to replace the front gasket, correct? Only leaks when running.
Looks like it's coming from here
Yeah, I've already done that so hoping this won't be too much hassleLook at the bright side ... at least changing the gasket will give you a chance to finally clean up that crusty engine and exhaust.
Do you have more information on this? What should I be looking for? If it's worth replacing while I'm in there I'd def like to do it. I've already replaced the mechanical seal and replaced the clutch plates/springs. Running great aside from this oil leak.While you're in there take a look at the Tach/cam cover seals, gaskets
If there is no sign of leaking from the gasket or from the tach cable oil seal then do nothing.Do you have more information on this? What should I be looking for? If it's worth replacing while I'm in there I'd def like to do it. I've already replaced the mechanical seal and replaced the clutch plates/springs. Running great aside from this oil leak.
I had not considered this... I have removed the tachometer cable (using Trailtech Vapor gauges). I wonder if maybe I didn't plug the hole (where the old tach cable was) and it's leaking from there. Trying to figure out the best way to test this.It could be that the leak is actually above at the tach drive, and the case gasket is fine.
You shouldn't need to rely on a plug to keep the oil in. There's an oil seal for that.I had not considered this... I have removed the tachometer cable (using Trailtech Vapor gauges). I wonder if maybe I didn't plug the hole (where the old tach cable was) and it's leaking from there. Trying to figure out the best way to test this.
Clean the area around the suspected leak then apply a powder such as talcum or flour. Run the engine until you see some oil leaking. The track in the powder will tell you if the leak is from the area you suspect or from higher up. If it is indeed from higher up behind the radiator then the next step would be to remove the radiator and see what is happening there.Trying to figure out the best way to test this.
