1 - 8 of 8 Posts
I seem to have oil on my left exhaust from a drip, oil on one carb and also around the fuel tap, any ideas?
Fuel leaking from the petcock could well run along the outside of the hose to the carb resulting in the staining there.
If there is oil and not fuel residue on the exhaust, it may be a different issue, like a leaking gear shift seal.
I think I'm seeing a track on the fuel and you mentioned that the staining is also "around the fuel tap". I'd start by checking that the nut that attaches the petcock to to the bung on the tank and the hose clamp where the fuel line attaches to the petcock are done up properly.
And when that is dealt with loosen the clamp where the carb meets the boot from the airbox and re-seat the carb in the boot.
BTW: Welcome to the forum. Please add your location to your profile and your bike's model and model year (NOT year first registered as your UK ownership will indicate) to your signature so that you don't have to remember to tell us every time and we don't have to keep asking when you forget (see Forum Settings link in my signature).
1 - 8 of 8 Posts
