I would highly recommend NOT using any oil additives.
Todays motor oils and their additives are like a fine cake recepie. Once you get all the ingredients balanced correctly, adding 4 more cups of sugar/flour whatever isn't going to improve the mix.
As for Slick 50, pure snake oil, there are better ways to piss away your money.
Do you put in oil additives if so what ones?
I was thinking of adding Slick 50 thinking that its a 1982 engine with 44,000 it might need a little help.
If you ever want your clutch to work again, I'd strongly advise against slick-50. Clutch shares oil with the engine.
I don't run any additives. However, GM EOS is a good additive for older engines. It replaces the zinc high-pressure additives that were removed in newer oils. Cars and bikes with flat tappet cams (like ours) still need the zinc.Absolutely not! Regular Slick 50 is not compatible with a wet clutch. You're not asking just to get a rise out of us are you?
Actually, I would avoid oils that contain high levels of moly too. It's a metal, friction modifier that Honda does not recommend using in certain models. Again, we're talking about the CX, so not a lot of power through the clutch plates anyway.
Shep, how do you know how much concentration you are adding? Why do you add when most oils have some concentration of molybdenum already? Just wondering.
Why do you think this? it was a question so I understand more, thought that was what this site is about......Absolutely not! Regular Slick 50 is not compatible with a wet clutch. You're not asking just to get a rise out of us are you?
I was reading the SeaFoam can, and while I have used it as a fuel additive, it also states it can be used in the crankcase oil. Anyone done this?
Mike
Chaz UK: The issue is that Slick 50 contains teflon (PTFE), which is really good at making things -- like your wet clutch -- slip.
Slick 50 is not great for anything.So great for a dry clutch then like in the car. well so far it look like Not to add anything.
Was asking as I am about to do a oil change Got new filter and o rings just need to get the oil now.
