1 - 6 of 6 Posts
Hi to all,just doing a little work on mates sons pit bike and cannot get it to fire,first of all i have washed out fuel tank,give carb a good cleaning(even took carb of running bike to no avail)fuel getting to carb ok,also got a very good crisp blue spark at plug,dont seem to be getting fuel into cyclinder.could it be mixture screw setting on carb, or could timing be that much out that it would not make an attempt to fire.
Many thanks to all in advance,thanks for looking.
does it run if you put some fuel down the cylinder? have compression
if so:
Points ignition? Check for a sheared flywheel key causing slipped timing.
FYI: there is an off topic section for OT posts, some folks get ugly about that sort of netiquette, I don't mind... we all learn.
But its a motorcycle, I suppose... Maybe a China made honda clone ? More info on this might help.
check to see if fuel is coming out of the tank, then out the petcock, to the carbs,,, is the float stuck?
I like this place for my pitbike stuff.
http://www.hooperimports.com/dept.aspx?dept_id=23
I own a Lifan 50 cub clone.... just like the CX, it will act bad with anything other than the stock airbox thingy... Mine would not start with a KN cone, it did look cool though.
1 - 6 of 6 Posts
