1 - 7 of 7 Posts
Just got my bike back on the road, and now the neck bearings are starting to make a creaking sound. Is there anyway to grease them with out taking the triple trees off? Maybe a grease gun with a needle point.
They do not seem to wobble, but should I replace them anyway? Are there complete roller bearing sets that I can buy? What part number and where would I go?
Thanks Ken
A good test: Put the bike on the centerstand and have someone sit on the back seat so that the front wheel is off the ground, or put it on the centerstand and put a jack under the engine so that the front wheel is off the ground, then slowly use a finger to push the steering right and left. It should be perfectly smooth left and right and should not want to return to any particular spot, if there is any hitch in the movement or if the steering tries to self-center then your bearings are shot and should be replaced.
All Balls makes a really good set of roller bearings for our bikes, They are Dennis Kirk Part #: 121431, All Balls Part #: 221011, about $45 or so.
Part 121431 fits the following machines:
1972 Honda CB350F Super Sport
1973 Honda CB350F Super Sport
1974 Honda CB350F Super Sport
1973 Honda CB350G Super Sport
1968 Honda CB350K
1969 Honda CB350K
1970 Honda CB350K
1971 Honda CB350K
1972 Honda CB350K
1974 Honda CB360G
1975 Honda CB360T
1976 Honda CB360T
1978 Honda CB400A Hawk Hondamatic
1975 Honda CB400F Super Sport
1976 Honda CB400F Super Sport
1977 Honda CB400F Super Sport
1980 Honda CB400T Hawk
1981 Honda CB400T Hawk
1965 Honda CB450K Super Sport
1966 Honda CB450K Super Sport
1967 Honda CB450K Super Sport
1968 Honda CB450K Super Sport
1969 Honda CB450K Super Sport
1970 Honda CB450K Super Sport
1971 Honda CB450K Super Sport
1972 Honda CB450K Super Sport
1982 Honda CB450SC Nighthawk
1983 Honda CB450SC Nighthawk
1985 Honda CB450SC Nighthawk
1986 Honda CB450SC Nighthawk
1971 Honda CB500K
1972 Honda CB500K
1973 Honda CB500K
1975 Honda CB500T
1976 Honda CB500T
1975 Honda CB550F Super Sport
1976 Honda CB550F Super Sport
1977 Honda CB550F Super Sport
1975 Honda CB550K
1976 Honda CB550K
1977 Honda CB550K
1978 Honda CB550K
1983 Honda CB550SC Nighthawk
1979 Honda CB650
1980 Honda CB650
1981 Honda CB650
1982 Honda CB650
1980 Honda CB650C Custom
1981 Honda CB650C Custom
1982 Honda CB650SC Nighthawk
1983 Honda CB650SC Nighthawk
1984 Honda CB650SC Nighthawk
1985 Honda CB650SC Nighthawk
1976 Honda CB750A Hondamatic
1977 Honda CB750A Hondamatic
1978 Honda CB750A Hondamatic
1976 Honda CJ360T
1977 Honda CJ360T
1968 Honda CL350K Scrambler
1969 Honda CL350K Scrambler
1970 Honda CL350K Scrambler
1971 Honda CL350K Scrambler
1972 Honda CL350K Scrambler
1973 Honda CL350K Scrambler
1974 Honda CL360K Scrambler
1975 Honda CL360K Scrambler
1968 Honda CL450K Scrambler
1969 Honda CL450K Scrambler
1970 Honda CL450K Scrambler
1971 Honda CL450K Scrambler
1972 Honda CL450K Scrambler
1973 Honda CL450K Scrambler
1974 Honda CL450K Scrambler
1979 Honda CM400A Hondamatic
1980 Honda CM400A Hondamatic
1981 Honda CM400A Hondamatic
1982 Honda CM450A Hondamatic
1983 Honda CM450A Hondamatic
1978 Honda CX500
1979 Honda CX500
1979 Honda CX500C Custom
1980 Honda CX500C Custom
1981 Honda CX500C Custom
1982 Honda CX500C Custom
1983 Honda CX650C Custom
1983 Honda CX650T Turbo
1982 Honda FT500 Ascot
1983 Honda FT500 Ascot
1989 Honda GB500
1990 Honda GB500
1976 Honda GL1000 Gold Wing
1981 Honda GL500I Silver Wing Interstate
1982 Honda GL500I Silver Wing Interstate
1981 Honda GL500 Silver Wing
1982 Honda GL500 Silver Wing
1983 Honda GL650I Silver Wing Interstate
1983 Honda GL650 Silver Wing
1983 Honda VT500C Shadow
1984 Honda VT500C Shadow
1983 Honda VT500FT Ascot
1984 Honda VT500FT Ascot
1984 Honda VT700C Shadow
1985 Honda VT700C Shadow
1983 Honda VT750C Shadow
1988 Honda VTR250 Interceptor
I think since you're going to have to remove them to regrease them anyway now would be a good time to replace them so you have a set of a known age, the tapers listed above are a good upgrade anyway.
Here is something I wrote up a while back on head bearings!
Checking Head Bearings
This procedure is very hard to explain even though it is very easy to do ... If my directions don't do it for you ask a mentor to show you. I was showing someone earlier this month how to do it and discovered that my GL650I head bearings were shot!!! I had checked them at the beginning of the riding season, so that shows they can go out at almost anytime on anyone.
To check the head bearings have someone sit on the back of the bike so the rear wheel is firmly on the ground.
Then go to the front of the bike and kneel down in front of it and grab both lower forks firmly with your hands. Pull slowly forward and push slowly backwards feeling for any movement. Be sure that you are no compressing the springs at all and confusing that with movement back and forth. This tells you if the bearings are loose and need adjusting. Sometimes it can also show that the forks are worn out ... so if you aren't sure ask someone who knows to test them for you.
To test for shot bearings (Not the same as loose bearings) while that person is on the back of the bike by putting one finger very lightly on top of or on the end of the handgrip of the bike. Then move the handlebars every so slowly (about a minute lock to lock) back and forth feeling for a very slight notch or stop in the rotation of the bar. It is usually very near to having the wheels straight ahead that you will normally find the notching effect. If you feel it drop into a notch that means the bearings are shot and need replacing.
You can have loose bearings and not have them shot, but you cannot have notched bearings without them being shot.
I hope this doesn't confuse you ... if it does I always recommend that you find a mentor to help you and when you become equal to that mentor you become a mentor to someone else.
Must be an echo in here. I'm seriously thinking this is my next project too. I have a strange, intermittent vibration or wobble that bugs me at times.
When checking for loose bearings as per the method outlined above it can be good if you are the one sitting on the bike while you get someone else to push/pull the forks.
Then you can put your finger under the top triple clamp against the joint between the upper cup and cone to feel if there is any movement at this point. If there's play you will feel a "nibbling" sensation on your fingertip.
This helps to make sure that any play found is not actually in the fork bushes or elsewhere.
1 - 7 of 7 Posts
