My bike started recently with a chrip noise from the area behind the radaitor. Any ideas what i need to fix?
Cooling fan? Dry tach cable? The fan would be the more likely and the one you would want to repair first. If you have a blade ready to let go, it can take the radiator out with it.
No loose bolts that i found and No aftermarket guards. how can you tell if the tach cable is the problem?
