Okay, so let's get right into it. I've posted before about this issue, but it was quite long ago, and I have actually done the work now to test things.
First off, the main issue.
I'm getting no spark to my left cylinder at all, and the spark on the right cylinder seems quite weak. This is what originally brought the bike to a garage decoration. I swapped out the coils, and the same thing, so the issue was not the coil. I then replaced my CDI with one I bought from someone on craigslist. Swapped them out, and tried. The issue persisted. I then set to testing them. My multimeter doesn't have the x100ohms setting, nor the xkohms setting that the FSM says to use, so I set it to the lowest setting of 200ohms, and tried testing the CDI and got quite literally no reading from anything at all, so I'm not certain as to whether or not the new (still off of an old bike that was being parted out) CDI, or the original CDI are functioning properly. That being said, I went through the steps to test the stator provided on motofaction.org/motorcycles/honda-cx-gl/stator-test/ and it came back with this, picture in first response.
So, I tested all the connections it told me to, and they all said "correct" after I submitted the numbers, but it still told me "some of the coils on your stator are faulty". So, assuming they're not just telling me this so that I'll buy their CDI replacement, and I really do have a faulty stator, I either need to replace, or fix my stator if I can. This leads me to the issue of leaking gaskets as the engine has nearly 60k miles on it according to the odometer that hasn't worked since I got the bike, because the speedometer hasn't worked. I've put probably about 500-1000 miles on it. pretty sure it reads 54k or 57k. Don't remember off the top of my head. So, if I'm taking the engine off, I intend to replace the gaskets so it stops leaking everywhere.
Finally, I suppose I need advise on the spark issue, would like some input on the idea of a "full" rebuild. Still need to test compression, but the bike was running before I lost spark, and it ran quite well even, so I don't think I likely have many internal issues (worn piston rings, chipped or broken valves) besides the stator. I could out run my buddy on his CB750 who's speedometer topped out at 135. Lastly, as far as the stator goes, should I replace the stator, and hope for the best, or should I bite the bullet, and get the ignitech CDI replacement that's going to cost me about $100 cuz the only two online are in Germany? Are there other options, or ideas?
Any and all input so long as constructive would be cool. Thanks,
Micah
Micah
