1 - 11 of 11 Posts
Just bought this bike for 500. Front brakes dont work. The lever isnt limp. It has a small amount of resistance but doesnt get harder if i pump the brakes and can push the cylinder. Thought bleeding the brakes would be the first step. But it wont build any pressure. Any tips?
81cx500 custom
Rebuild the caliper and replace the master cylinder. Many here have been happy with cheap ones from ebay. If the brake line looks to be original replace it too and preferably with a ss one.
1981 CX500D, 1976 RD400C, 1972 H2 750
Disconnect brake line from master cyl, fill master cyl, place finger over outlet port and pump master cly....repeat till it pushes your finger off, connect line now it should bleed normal.You will have to remove your finger from the port to get the trapped air in master to escape.
Or just tickle the lever until the air stops rising from the bottom of the master and then start to bleed.
The hoses can fail internally but look fine from the outside. Disconnect the line at the caliper and pump the lever. If you don't get a squirt each time you move the lever, change the hose(s). Now when it comes time to bleed the system., cover any painted parts with a towel, fill the reservoir. Now take the assembly off the handlebar and hold it vertical so the trapped air bubbles can rise up through the banjo fitting and make the 90 degree turn into the reservoir. Pump the lever a bit in this position, then reattach to the handlebar. If you don't do that chance are it will take you all day.
It won't take all day without finger bleeding. Try tickling the lever just enough to make the brake light switch click.
I never finger bleed.
I changed a master cylinder in the last week without even getting air at the bleed nipples. Took less than a few minutes to just pump the fluid in the lines through.
Of course, it may now be too late for this approach to work.
Of course if you use a vacuum pump you don't have to worry about any of that.
81cx500 custom
You need to use a vacuum pump. I have a 1981 CX500 Deluxe and messed with all kinds of methods for a week, then purchased a vacuum pump and in 30 seconds front brake pressured up.
Certainly there are several methods that will work effectively, vac pump being one. Marks vertical method also is effective. I have a vac pump in my toolbox as it is useful for many tasks.
1 - 11 of 11 Posts
