1982 GL500 Interstate
I do not have power to the blinkers. I have power to the headlight, but the blinker do not power on. No power to the blue or blue/white or the orange or orange/white wires. The blinker switch was working perfectly until I unplugged the wires. I studied the diagram but cannot seem to figure it out.
Do the front 2 signals come on as Running Lights?
All fuses good?
Does the turn signal switch make contact?
The switch was working perfect before I removed the windjammer.
I think the running lights may be the blue/white and the orange/white. The blinker fuse is good.
It appears there is no power going to the blinker indicator either.
I no longer have the windjammer and wiring harness.
Which wires are powering the blinkers?
Discussion Starter · #4 · (Edited)
It appears to be working now. The blinker function is super slow. I will try another flasher and see if that helps.
You mounted aftermarket turn signals when you removed the fairing? Are they LED?
The stock thermal flasher needs a minimal amount of load to get hot enough to cycle. Aftermarket signals might not provide that.
A three prong digital flasher should fix it.
Reactions: washoe
