1 - 10 of 10 Posts
1982 GL500 - Delaware County NY, in the Beautiful Western Catskill Mountains!
I'm new to the game of doing a build/modifying a bike, but have been riding for 35+ years. VERY happy to have found this site and appreciate all the info sharing and I hope to share pics and stories of my build. Thanks in advance to everyone for your help!
I have a similar project that I started years ago. Unfortunately, it also stalled years ago.
Here's some history, if it helps you with any ideas:
Reactions: Warrigol
Thank you so much!! Great advice that I will certainly take!
THANK YOU!!! I can see your vision and hope you get motivated to continue onwards once again!
I've had a little more garage time the last couple years, but other projects keep butting in line. I'm hoping for a little progress this summer.
1 - 10 of 10 Posts
