1 - 6 of 6 Posts
OK, I know this is probably a total newbie mistake but I just made it, feel free to laugh at me if you like;) I needed to adjust my idle speed because it was high (3000rpm) and a friend told me to adjust the pilot screw, so thats what I did. I got it running (although not warmed up like I should have) and adjusted the pilot screw on the right carb counter clockwise... nothing happened. Then I tried going clockwise and nothing happened again. So I tried to put it back where I thought I had started from and left it for about an hr. When I came back, it started right up, then the RPMs slowly started to drop and then drop some more and that was the end of it. I havent been able to get it running since. Every so often if I pull the choke out, it will start but quickly (in about 10seconds) shuts off again. I have tried adjusting the pilot screw back to its original point but Im afraid that Im just making it worse. Does anyone have any suggestions for me. Is there a good way to diagnose whats going on? Or is this a common mistake with an easy fix? it seems like its all in the pilot screw since that is the only think that I adjusted. Could my carbs be out of sync since I only adjusted the pilot screw on the right side?
-photocodo
The pilot screws are directly in front of the float bowls. Initial setting should be 2-1/2 turns out from lightly seated. Unless someone has removed the caps on these, or otherwise modified the bowl, they cannot be adjusted but 3/4 of a turn. I doubt that these are your current problem.
The idle speed adjustment is a black plastic knob between the carbs on the bottom. Normal idle is around 1100 RPM. It almost sounds like a PO has adjusted the idle very high to keep the bike running. It probably needs a GOOD carb cleaning. Not just a spray down, but removal of all the parts, soaking and cleaning. Ultrasonic cleaning works best, but you can get by without. I suggest getting Larry's carb book if you don't feel comfortable taking these apart.
Syncing may be necessary down the road, but it is probably not causing your problems either.
Do you have a full tank of gas?
as blue said,try and get your idle to 1100rpm.number 10 here
Did you get the issue fixed. I just went through carbs as a new 1981 gl500 owner located in Tampa. It does appear they are very picky carbs and now this new to me bike is running great.
I just finished going through the carbs on my dad's bike. The pine-sol trick works great. Just go slow, remember where everything goes, and you'll be good to go.
-Brendan
1 - 6 of 6 Posts
