1 - 17 of 17 Posts
Welcome to the forum. Please add your location to your profile so that it will show when someone mouses over your name (see Forum Settings link in my signature).
l I note that you have listed your bike as an '84 CX500C but Honda stopped making the 500cc models for most places after the 1982 model year. Is it possible that yours is an earlier model that was first registered in 1984?
Knowing the correct model year of your bike is important because there were changes from year to year. This is particularly important for the CX500C because all model years up to 1981 have the original Capacitor Discharge Ignition (CDI) but the 1982 model has the later Transistor amplifier Ignition (TI or TAI).
This page may help you figure out what you actually have
Honda cx500c
About year of production,well it's specificed as "on the Road since 03/'84...I'll try to find the year by serial number,thanks.Is there a place on the bike where the year is listed?
Serial nos of frame and engine will tell you the production year.....sometimes for USA imports theyll also have a federal compliance plate....
E.g. for my 750 Usa model built 10/78.
Honda cx500c
Thanks,I allready tryed to find it by SN.
No luck.It's imported from germany 27hp...can you tell me where to find the year by SN?
According to the page I linked in post #6 of this thread the 27Kw (= 36HP) CX500C was imported to Germany in 1980 and 1982
According to the Honda parts book I have, covering the 1980 'A' models and the 1981 'B' models, both Full Power and 27PS (it's PS not Kw, so a little under 20Kw) versions of both the Standard and Custom CXs were imported into Germany.
1 - 17 of 17 Posts
