Just purchased 2 frames and motors a 78 GL500 and an 81 CX500 plan to build a bobber out of one and a hardtail out of the other.
'78 Cx500 and '81 GL500?
Welcome aboard!
And welcome to the world of antique vehicle ownership (they own us, not the other way around). I'm not sure how much of the following applies if you have just the frames and engine but your bikes are about 4 decades old and may or may not have had all of the maintenance necessary to keep them safe & reliable so it is highly recommended to download the Factory Shop Manual for your model (available through the CX Wiki - link in my signature) and go through all of the service procedures, regardless of whether the bike has reached the specified mileage.
If you are new to motorcycles I would advise against making wholesale changes to them until you at least have a chance to learn a bit about how bikes work in general and what riding is like so that you have a basis of comparison to tell whether the changes made things better, worse of just different.
