I just purchased an 83 CX650 custom in pieces. Guy that I got it from said the starter clutch was bad. I have done some reading around the forum and found that the 650 starter is weak and should be replaced with a GL500 starter. I also have heard that there are 3 bolts to watch out for. The motor was already pulled and the cover taken off the side so I don't know what has come off already. I did notice the plate with teeth under the stator is loose and spins freely and looks like it may be bent. I also read somewhere that getting an entire assembly from a gl500 will prevent me from having to loosen the bolts and will make the setup more reliable. I would like advice on what I should do to get this back together and running and where the best/cheapest place to get parts, gaskets, etc. I am pretty mechanically inclined, just not familiar with this specific engine. I included some pictures to help. Thank you.
