Well I had never seen a CX until a month ago and now I have 2.
1980 CX500C making into a scrambler
1981 CX500D making into full cafe with CBR600RR front end
202002
202003
Loop
Welcome, it looks like you have a solid start there. Do they both run?
Discussion Starter #3
Yes they both run, but the Deluxe needs a CDI. I borrowed the CDI from the Custom.
Welcome to the forum. Please add your location to your profile and your bikes' models and model years to your signature so that you don't have to remember to tell us every time and we don't have to keep asking when you forget (see Forum Settings link in my signature).
And welcome to the world of antique vehicle ownership (they own us, not the other way around). Your bikes are about 4 decades old and the Previous Owners may or may not have done the maintenance necessary to keep them safe & reliable so it is highly recommended to download the Factory Shop Manual for your model (available through the CX Wiki - link in my signature) and go through all of the service procedures, regardless of whether your bike has reached the specified mileage.
