1 - 2 of 2 Posts
Welcome to the forum and welcome to the world of antique vehicle ownership (they own us, not the other way around). Your bike is about 4 decades old and may or may not have had all of the maintenance necessary to keep it safe & reliable so it is highly recommended to download the Factory Shop Manual for your model (available through the CX Wiki - link in my signature) and go through all of the service procedures, regardless of whether your bike has reached the specified mileage.
I also recommend looking on all rubber parts with suspicion because rubber does not age gracefully. You probably already know to check the date codes on your tires and replace them if they are over 5 years old no matter how good they look & feel (old rubber simply cannot flow around the irregularities in the asphalt well enough to grip, especially if it is cool or wet) but a surprising number of people don't realize that the original rubber brake lines should have been replaced every 2 or 3 fluid changes (= 5 or 6 years) too so if your bike still has rubber lines I recommend shopping for modern stainless braided ones (they last practically forever and double the life of the fluid).
And don't forget things like the rad hoses and the boot between the engine and swingarm (they can crack on the bottom where you don't see it).
1 - 2 of 2 Posts
