Yeah. Like I said earlier, it's a hybrid RHB5 / RHB3. On the intake scroll it should be stamped VG1.
Rebuild parts are the bearings and other small parts ( google : RHB5 rebuild kit )My last exchange with [email protected] was:
"We have access to the rebuild parts. We cannot convert it to watercooled. We can rebuild it for $370.
I think an factory produced turbo can never be a hybrid ! Hybrid is the term used when people start to mix different turbo partsYeah. Like I said earlier, it's a hybrid RHB5 / RHB3. On the intake scroll it should be stamped VG1.
I am sure the shaft is welded to the Turbine wheel.I'm not so sure they're welded. When I inquired a while back about changing from foil to ball bearing in the center housing, I was told the ball bearing shaft was different from the foil bearing shaft and that the turbine wheel couldn't be pressed onto the BB shaft.
A Honda Turbo bike is complex enough to keep it running. Rebuilding one from a basked case will consume a lot of more time !Have full paper Manual just not enough time . I have three other bikes I'm working on . I just reworked the carbs on my cavalcade just to find out my intake boots leak Sucks !! When I get it working right ..ill start on the cx500 unless I need more money then ill part the cx
Sounds about right, except I can't balance it.Rebuild parts are the bearings and other small parts ( google : RHB5 rebuild kit )
Normally a rebuild is based on that the Turbine, Compressor Wheels and Housings are not damaged.
So the $370 dollar is 50 dollar parts + 320 dollar labour![]()
You mean, like the factory?I think an factory produced turbo can never be a hybrid ! Hybrid is the term used when people start to mix different turbo parts
Fair enough, I suppose. All I know is what they told me- it would be possible if they could press the turbine off the old shaft and onto the other, but they couldn't.I am sure the shaft is welded to the Turbine wheel.
And yes there is a slight difference in diameter between the glide bearings ( RHB5 ) turbo's and the ball bearing ( RHF5 ) turbo's, so they don't mix/exchange
