Welcome to the forum. Please add your location and your bike's model and model year (NOT year first registered as UK paperwork shows) to your profile so that you don't have to remember to tell us every time and we don't have to keep asking when you forget (see Forum Settings link in my signature).
And welcome to the world of antique vehicle ownership (they own us, not the other way around). Your bike is about 4 decades old and may or may not have had all of the maintenance necessary to keep it safe & reliable so it is highly recommended to download the Factory Shop Manual for your model (available through the CX Wiki - link in my signature too) and go through all of the service procedures, regardless of whether your bike has reached the specified mileage.
Re the stalling problem, a couple of things come to mind.
You are squeezing the lever to disengage the clutch before you put it into gear, aren't you? (If you are an experienced motorcyclist this may seem obvious but we do get people who have never operated a manual transmission on occasion)
Assuming you are using the clutch properly, is it adjusted correctly? If it is dragging there will be load on the engine as soon as you put it into gear even with the lever squeezed.
What is the idle RPM set at? If it is too low that could cause the engine to stall when you engage the clutch in gear.
I'm sure others will be along with more (possibly better?) suggestions.
