1 - 3 of 3 Posts
'80 CX500C
Hi All,
Great to be here. I've just purchased my first CX here in Australia. This is my first project, so I'm looking to pick up the basics of maintaining these bikes and making a trip down to Tasmania before eventually going for a cafe racer build.
I've been learning off youtube mostly and started off small, have replaced a few cables and hoses, and now working on a carb rebuild. I got a tip-off from a great mechanic who works on CX's that Mikunioz Carbs are the way to go so I might test them out too pretty soon.
Anyway, looking forward to talking shop!
Tim
208262
81 cx500 custom
Nice bike, I just picked up my first running cx. Same color as yours. I'm in the process of replacing front end seals and gaskets. I had a bad oil leak.
Welcome to the forum. Please add your location and your bike's model and model year and welcome to the world of antique vehicle ownership (they own us, not the other way around). Your bike is about 4 decades old and even though it looks like it has been well looked after the Previous Owners may or may not have done all of the maintenance necessary to keep it safe & reliable so it is highly recommended to download the Factory Shop Manual for your model (available through the CX Wiki - link in my signature) and go through all of the service procedures, regardless of whether your bike has reached the specified mileage.
1 - 3 of 3 Posts
