1 - 3 of 3 Posts
1980 CX500 Custom
Discussion Starter · #1 · (Edited by Moderator)
My first bike was a CX500 Custom I bought for $400 when I was 18 or 19. Since, I’ve had a few other bikes but, at 51, I just bought another CX500 Custom, same color as my original but this one was $750 and in need of a lot of work. Planning to turn it into a scrambler as I live on a dirt road.
Displaying IMG_3252.HEIC
Posting pics works better if you click the place in the text box where you want it and drag the pic into the box. I did that for you (in this case by clicking the thumbnail/link you posted and dragging the pic from that window) to show you how well it works.
Welcome to the forum and welcome to the world of antique vehicle ownership (they own us, not the other way around). Your bike is about 4 decades old and may or may not have had all of the maintenance necessary to keep it safe & reliable so it is highly recommended to download the Factory Shop Manual for your model (available through the CX Wiki - link in my signature) and go through all of the service procedures, regardless of whether your bike has reached the specified mileage.
1 - 3 of 3 Posts
