Ok guys, I am 100% brand new to old school motorcycles..... I just picked up a 1981 Honda GL500. Got it for really cheap as as a project bike, the engine runs strong and I rode it around for a bit before I got it. But, as expected I have some problems, and don't have a service manual ... YET. I need some help from all you experienced guys and gals. Ok here is the first problem. My battery is at autozone right now, Im trying to eliminate that from the problem. The bike has 50000 miles, and the guy i bought it from has had it for about a year, and hasn't rode it at all really. When I went to first look at it, the bike was running in his driveway. He said he had to jumpstart it because the bike hasn't been running in a while. So obviously I ask "Does it need a new battery?" He said no the battery should be fine, its only a couple months old. Ok, so asked if I could ride it, he said sure, I rode for a bit, then stalled the bike (not used to the clutch). I fired it back up with the electric start.... it started. Rode it stalled it again lol.... didn't start the third time. So in total... it was running for about 5 minuted before I got there. Ok... so the day after, I purchased the bike, he brought it to my house, we tried to start it, wouldn't start.... he said probably because its been sitting in the truck ...etc. Ok so I tried to jumpstart it, wouldn't start. It will run for a minute, but then dies. Hope its a bad bettery.... but I guess we will see. Any input or help would be great...I just really hope its not the stator, regulator, or any part of the charging system.
Problem 2. Sorry this is so long. The choke is rigged up with a little metal piece right now that you have to manually pull because the choke cable is not currently on the bike. How do I get to the inside where the choke attaches to put this cable back on? it runs up under into the bike somewhere, but its looks kinda difficult to get to, although I haven't even tried yet, just hoping you guys have some pictures or a simple way to do it.
Ok and finally I am going to change the oil tonight. Also, what other fluids should I change ? Has anyone used a product called "Seafoam" and is it ok with the bike? Ive used in in my fuel tank on my newer motorcycle, but never in the oil or through a vacuum hose. What vacuum hose on the gl500 would I use for this?
Ok well thanks guys, an sorry for all the questions, any help would be appreciated. Thanks a lot!
