1 - 11 of 11 Posts
New to the world of CX500's and new to this forum. Just brought home yesterday a 1978' CX500 with 17,000 miles that hasnt run in years. All original non modified bike that is a little rought and needs to be completely gone thru. Need to see if I can sort out low compression in both cylinders, 60 PSI in left cyl and 90 PSI in the right. Hoping these numbers will come up once I get it running. I have wanted one of these CX500's for years and have been playing with older (90's) Harley's. Just finished a custom 97' Harley Sportster 883 Scrambler build in March this year and decided I needed another project. Originally I wanted to do a custom build with this bike but thinking about restoring it? Need to get it running first and then see how I feel. G.B.
The low compression could be simple as poor valve adjustment or stuck piston rings or testing technique.
You are making a good choice to get it into running condition before any modifications.
At 17K miles, that bike is barely broken in. Likely only needs a good maintenance job.
Discussion Starter #5
It just dawned on me after trying to look the bike over from top to bottom when I was buying the bike that I did not hold the throttle open when I did my compression checks. I just reran the test removing both spark plugs and making sure to put a little grease on the compression tester o-ring. With the full throttle cold I got 85 PSI in the left cyl and 100 PSI in the right. Still not happy with the 20% difference but it is what it is right now. However, the motor will definitely run with those numbers and still hope it comes up a little more after it is running.
"However, the motor will definitely run with those numbers and still hope it comes up a little more after it is running." What he said. Get this done if you can before drawing any conclusions. But, check the WIKI for start-up recommendations after a long period of non-running.
Keep it stock, at least until you can ride and find out if it wants any changes. My Standard is mostly stock, and there's little that I would want to be different.
while I agree for the most part, I've never had a bike tell me what it wants to be? BTW I had a 78 new off the showroom. still miss it.
They are only original once, here is another vote for bringing it back to its former glory as opposed to customizing it.
Welcome aboard! I grew up just North of Detroit. 11 mile & John R
That's beauty! I vote for Restore! Learn what you can from this bike and get an ugly basket case to customized.
There are few good '78's left out there, and although I stay out of the whole "keep it stock!" debate, just want to point that out, if it were me, I would not chop it up.
1 - 11 of 11 Posts
