I haven't been able to run my bike in a while. Too busy, whether is... well, exactly what you'd expect from Portland in Oct/Nov, 40 degrees and raining everyday, and I was more than a little worried going out to start the bike this morning. I think she's been ridden twice since I moved down here in September. Old gas, gummy carbs, sitting in the rain for months on end, trying to start her when it's below 40 out.
I had to keep on the started for a second, but she fired up. I let her get warm and then took her 25 miles or so down to Damascus. After ten miles or so, the idle was damn near perfect, throttle pull was perfect... she ran as if I'd been riding her daily. By the time I got home after putting about 50 miles on... unreal. I stopped to get breakfast and read the paper, came back out, pipes were warm but not hot, I gave her zero choke, just hit the starter, engine spun once and started.
The bike has 55,485 on it and I've done NOTHING mechanical to the bike in about a year.
So, that all being said, there was one problem. Once I picked up the DSL modem I went out to Damascus for, on the way back when I let off the gas she started popping real bad, like she does when she needs gas. Luckily, I was right next to a gas station so I pulled in and filled up. She only took 1.2 gallons. Hmm. Didn't need gas. Even after getting gas she kept doing it when I let off the throttle. Hard and big pops too. The idle got a little low as well but she didn't stall. Then, poof, it when away.
Now, I have a hunch. Someone at some point apparently lined the tank without removing the filter inside the tank. Once I figured that out I removed the in tank filter and just put an exterior in line filter on. It's worked fine ever since but she tends to start popping and gets thirsty long before she should actually need gas. Then today, I'm guessing something got stuck near the petcock inside the tank and blocked fuel flow.
Does that sound reasonable? Does that sound like a likely culprit? If so, where do I go from here? I was reading the long distance build up thread and read how Larry put gravel in the tank and all that. Should I look into doing something similar? Gravel, muriatic acid, coke, water and a new liner? Is that the idea? Or am I on the wrong path and this is likely being caused by something else? -Nick
