Hello all!! I'm new to this forum.
I recently acquired a 1983 GL650i. The bike starts up and drives.
The motor is leaking oil where the rear housing bolts up and water from the weep hole.
My wife just had our 3rd child so the bike needs to be put on the back burner. Even though I can't work on it, I am just thrilled that I found the bike I've been looking for!!
So I'm thinking about storing the bike for about 2 years and looking for suggestions since it won't be operational(just looking pretty). I live in Arizona where it gets very hot in summer but not bad in the winter. I am able to park it in my garage so it won't be exposed to the elements.
What do I do about fuel in carbs and tank? I have heard to drain carbs but leave tank all the way full and have heard to drain everything. So what is best?
My oil level is fine and looks good. It only leaks when running. Is that ok to leave as-is?
As for the coolant system. The water is slowly weeping running or not. I don't know if the right mixture is in it. It could be just pure tap water???? Do I drain it all and put 50% / 50% in for storage or leave it dry?
I am going remove the battery, top it off with distilled water and apply trickle charge.
The bike will be on center stand, my tires look great. Should I over inflate them and if so to what PSI?
Any other suggestions for storage would be greatly appreciated.
Thanks, Josh
Thanks, Josh
