I've got a small but persistent oil leak from my cam chain tensioner lock bolt. I'm not really sure why since I installed a new o-ring on it only 2 years ago when I changed the cam chain and tensioner. It's enough that it leaves a slick sheen in the valley just below the inspection cap, not a pool of oil or anything but enough that it bothers me. I've tried using clear silicone liquid gasket and that hasn't worked, and I really don't want to have to drop the engine and take the rear cover off just to fix a small leak, but if I can't figure out any other way I may have to. Any suggestions?
EDIT: additional info, it was fine when I put it away in December, could the rubber o-ring have dried out over winter? If so, any chance you think it'll eventually swell and seal again?
