1 - 20 of 28 Posts
Hello,
I was just putting my bike back together, and decided to adjust the tappets while I was at it. To make a long story short, I loosened the cam chain tensioner bolt and rotated the engine, since I understood that it might help loosen up a stuck tensioner arm. Well, put it back together, and the bike ran for a bit, then seized. I can turn the engine a little by hand, but sometimes not all the way around, d=seems to depend on direction.
Anyone have a clue what is wrong? All the fluids are in the bike, oil is fine, ran fine the other day. I know it has something to do with what I just did, please help
Do I need to pull the engine?
Mike
chain might have gotten so loose it wrapped around itself.
I had a CB360 do that but i think that was because the chain on it busted.
Did it make a loud ticking sound while it was running. Almost like a chatter?
It seemed to make about the same or maybe as little more noise than usual - I don't remember the chain being long enough to wrap around it self. I was thinking something similar though.
Does this sound like an engine out job to fix?
Mike
A few months ago I had to examine a CX that had run fine for
50 miles after the ( second hand) engine was installed then it suddenly locked up
just as he got home and right outside his garage door.
This was kind of lucky in that it didnt happen at speed.
One theory was the cam chain had snapped.
Anyway, motor dropped, back off and the cam chain etc was all fine
I found I could turn the motor one way then the other but at certain
positions near RH TDC, it stopped dead.
"Aha! Dropped valve" says I
Well it was and it wasnt
Some outer parts of the exhaust valve had broken off and by the looks of it
had been bouncing around a lttle bit before jamming between the
valve and piston.
I'm not saying this is your problem Mike and hope it isnt but
it has to be a possibilty
Its too serious not to drop the motor and examine anyway
Best case scenario may be a broken chain guide jamming the works
Good luck!
Mike, you say it ran for a "bit", how long is that?
Probably slipped/jammed the chain when rotating.
You say that you can rotate it by hand. It that all the way around and several times? I would take the spark plugs out and rotate while watching the pistons with a small flashlight through the spark plug hole an see if there's anything in there. I would also watch the movement of the tappets to look and see if there is anything different going on.
It ran long enough to warm up a bit - it won't turn all the way round now. I took the fairing and some other stuff off and am going to take it over to my dad's house later to drop the engine and check the valves and chain.
Thanks for all the replies. I knew I should have left it alone, but you never know could have happened anytime I guess. Hopefully it is just the cam chain acting up.
Mike
Still taking it apart - one question though, could it be the starter clutch? I was spinning the engine both ways, could I fragged the starter clutch.
Have the headers off and the exhaust valves look good so far.
Mike
I doubt it Mike
lets say it seized to the rotor
The starter would be driven by the engine at all times
but the engine itself would stiil spin normally when you put a socket on the front
take the plugs out an get a good strong torch and move each piston up and down
as much as you can and see if there's any sign of damage
If you remove the rear cover first before you touch the heads and you're lucky enough
to find something fixable, you wont have to disturb the heads
Its possible something broka and jammed between the chain and gears
lets hope its anything but dropping a valve as thats bad news!
OK,
So, found the problem its actually incredible - I couldn't check the pistons, as the motor wouldn't move enough to let me inspect them fully.
Took the rear cover off, couldn't find anything binding it up, and started to get a bit worried. So, I tok the cam chain cover off, and guess what pops out? A ball bearing. I think it was from the steering stem... it must have bounced in there through the inspection port cover, I guess. When the engine was running it must have worked its way into near the cam chain.
Got rid of the ball, and like magic the engine spins free. Problem is that now I need a rear cover gasket, I was supposed to be going on a 4 day motorcycle ride this weekend, so I need to find a gasket close by or get one overnighted to me. Anyone know of a place that has them and does rush shipping?
Mike
I think there's a pattern for one on the dropio website and most any place that makes gaskets could do one for you. If I recall the thickness of the gasket material is rather important so you'll need that spec.
I guess I am a little puzzled as to how a ball bearing from the steering stem could get inside the engine through the inspection port. That would need to be one hell of a bounce. I would also think that getting jammed inside the engine could possibly cause some other damage. Hmmmmmm BillRod
You can buy gasket material by the roll and cut your own if your in a pinch/hurry/obsolete.
FOD eh?
tut tut !!
Well its a hell of a lot better than a dropped valve
I suggest you carefully check the affected parts
and cam chain for damage before reassembly
rear cover gasket:
I make my own so can you if your allowed to play with sharp things
and can source gasket paper about 20 by 16 inches ( 18X14 may do, its been a while)
and .8mm or 1/32" thick
EDIT:
Just remembered I have an aftermarlet one in the kitchen
and measured it.
Its .51mm ( 1/50th of an inch) so thinner than my home brew ones so you have a bit of latitude there.
Absolute minimum length and breadth is
16" high and 12" wide
I once dropped the ball bearing from my kill switch down the spark plug hole in the head of my XL-100 while
taking the kill switch apart, the handle bars were turned all the way to the right,,,I saw it go in the hole
though and was able to get it out with a small magnet on a piece of wire.
In a pinch people have been know to make them out of cereal boxes and similar items. I have a template of all my gaskets made up out of a Digorno Pizza box. Yep I mangled the spelling. But it seems to be decent enough for the job. But I prefer Honda gaskets on the rear. I trust them more.
Someone else. Maybe Phil suggested large manila envelopes.
I can understand why it would seem puzzling - I actually did the steering bearings yesterday, and did the cam adjustment / tappet check today. Only thing I can think, is that when the balls spilled out of the steering head, some must have landed back somewhere, where they got jostled and fell into the open port.
Funny thing is, I was just going to go for a ride instead of mess with the tappets, but figured the engine was cold so why not.....
What are the frickin chances of a BB going into that port anyway?? I mean come on...
I prefer the honda gasket for the rear case, I had an aftermarket one that didn't hold up, the honda ones seem to hold up well. Last time I tried to cut one it didn't work out all the well for me either, ended up leaking on me.
Mike
Mike do you have children out by your work area. From a kids perspective, I can see that little ball bearing on the floor and picking it up looking somewhere to put. Ah ha Daddys engine. Dtrops it in. There all bettr. lmao. Its just a possibility with children.
Well you need to get that bearing back up in the steering stem. That is if it isn't square now.
Glad you found the problem.
Discussion Starter · #19 ·
I do have a little one, she would have helped me if she was around, but the BB's helped themselves this time.
I replaced the steering bearings with a set of tapered bearings, so the little balls aren't needed anymore.
Mike
1 - 20 of 28 Posts
