1 - 7 of 7 Posts
Hey guys as the title says, I am looking to buy a used impeller, this year of bike only takes this type of impeller so it wont work to get a cx500 or GL500 so if anyone has a parts bike laying around I would love to get an Impeller from you. Or if anyone knows how to use my old one with the teeth that have been shredded down I would love to know how that works. thanks again.
I'm anyone :haha:
The principle:
Before:
Then after the work on the lathe:
What I did on the lath:
The "thingy" on the right side was an impeller of a CX500.
Cut down the fins/"wings" to the centrum/center with the splines.
Left side was a 650 impeller.
The bore in the middle was cut to the outer diameter of the cx500 "center".
Then pressed the 500-thingy into the 650-bore with using Loctite 648.
(Today I would set a dowel pin (diameter 4mm) axial between "thingy" and the bore.)
Ready to install.
What would happen to install an CX500 impeller and its waterpump cover instead of the 650 impeller and cover ?
Just a less flow rate.
And depending of the warm oder colder regions of the globus the electrical fan has to switch more frequently on and off.
:dontknow:
Average temperatures in Portland
1 - 7 of 7 Posts
